07-05-2013 02:47 AM
Please give me information about this type of error.
07-05-2013 04:01 AM
What error are you talking about?
07-05-2013 04:02 AM
Where is the error...???
07-05-2013 04:31 AM
when I want to start program comming this error and shows that IMAQ Write JPEG File 2 Is wrong
07-05-2013 05:13 AM
Have you tried wiring an indicator to 'Image Out' output of 'Kamerainställningar gigE_2(SubVI).vi' and check, if actually there is an image available at this output??
07-05-2013 06:03 AM
No. How can I do that?
07-05-2013 06:12 AM
You can find the same from 'Controls Palette' as shown below:
And on the 'Block Diagram', you'll see a terminal corresponding to this indicator. very similar to below picture... and that you need to connect to the wire.
07-05-2013 06:14 AM
I tried to delete it and fix another thing to save pictures! can you suggest another way to save pictures?
07-05-2013 06:32 AM
Actually i did it but I must find a way to save pictures JPEG
07-05-2013 07:02 AM - edited 07-05-2013 07:03 AM
To save a picture, you must be sure that, there is a picture available...!!
Try the attached code, and you'll see that 'IMAQ Write File 2' works beautifully, without any flaw..!!
So I suspect, the error you're experiencing is because there is no image available.. or also may be because there is an incompatible image that you're trying to input to 'IMAQ Write File 2'..!!
