10-17-2008 02:17 AM
Hi everyone,
I have a porgam in which I am using an array as a command (with specific values that the user enters before running the program). By mistake, at the beginning I created a 4 dimension array (for instance), but I didn't know because I was only showing the first 3 values (not expanding the array to 4 or more). I would now like to change the size of the array from 4 to 3. I don't seem to be able to find an option (right clicking on the array) that enables me to do this directly. I don't want to use the "reshape array" icon, because this is not what I want to do. I hope I am clear enough.
Thanks for any help,
regards,
Marc
Solved! Go to Solution.
10-17-2008 02:24 AM
10-17-2008 02:51 AM
10-17-2008 03:11 AM
ooops forgot the check element array options.... thanks a lot to both of you !
regards,
marc
