03-07-2005 06:35 PM
03-08-2005 09:14 AM
03-08-2005 12:30 PM
03-09-2005 08:05 AM
04-21-2005 02:14 PM
@DFGray wrote:
You can create something in LabVIEW to do this, but it won't be trivial. Here are some things to point you on your way. I have not done this, so it is pure speculation on how I would go about solving this problem.Good luck. One final question - do you really need an MDI? Floating windows with clear labels are a lot easier. Do some polling of your users to find out what they like best, then go for it.
- You will need to know ahead of time the maximum number of windows you will want. On your front panel, create that many individual subpanels. You can hide the border and make them transparent so you never see them unless something is in them.
- When you load a VI into the subpanel, all you get is the panel, not the title bar. You will need to create a title bar with buttons and any border you want on the VIs in the panel area. This is tedious, but fairly straightforward, especially if you use system colors to make it look like a real title bar/border. You won't be able to make it look like an XP title bar unless you use bitmaps/picture control. If you go that route, you can probably even mess with the color map to change the bitmap colors when the system color changes (have to poll, no event for system color change).
- You can resize and move the subpanels using property nodes. Getting the info to do this could be tricky, however, since you may be coordinating mouse events from the top level VI and the VI hosted in the subpanel. Should be doable, though.
- One other method is to use floating windows, but move them on top of your main window so it appears to the user it is an MDI. You won't get clipping, but everything else will look the same and you won't have to jump through hoops to create title bars, etc. You will have to write a position manager to maintain the window positions, but that is probably easier than the tricks I discussed above
05-14-2005 06:40 AM
05-15-2005 04:20 AM
05-16-2005 07:40 AM
05-16-2005 07:42 AM
05-16-2005 09:48 AM - edited 05-16-2005 09:48 AM
Message Edited by billings11 on 05-16-2005 10:06 AM
