12-24-2012 04:51 AM
hi JelleBenoot,
What file i am attaching, in this just give the path of an excel file with maximum number of row & col, than later select the datatype of columns. you will get the data in 2D array.
Let me know if you got any problem.
02-04-2013 09:48 AM
Any news?
06-25-2013 01:02 AM
could you please can pu vi code of this picture.
12-04-2014 08:00 AM
could you kindly send me the png file of getting the data from excel to XY Graph
12-04-2014 08:43 AM
Hello Susheel,
Why do you require the png?
The actual code is posted just above here.
12-09-2014 04:16 AM
Hii Thierry ,
I would like to plot the XY graph (2 vertical axes with pressure and temp and 1 horizontal axis time),in parallel the values are generated in excel sheet with 3 columns and with multiple rows.
Hence,How can i import the excel sheet columns and rows and plot the generated excel sheet values in XY graph of LabVIEW
Could you please suggest me .
Thanking you,
With best regards,
Susheel
12-09-2014 10:04 AM
Hello Susheel,
Thank you for your reply!
Can you share what you have already tried/made based on the llb above?
I don't mind debugging your code, but I want to avoid that i am writing code for you without you first giving it a try.
I would prefer to teach you something by using LabVIEW instead of just giving you the solution right away.
Keep in mind the following saying:
Give a man a fish, and you feed him for a day; show him how to catch fish, and you feed him for a lifetime.
12-10-2014 05:59 AM
Hey Thierry,
I have attached the sample work for your ready reference and the ideas of implementation.
Could you make the necessary suggestions further.
Thanking You,
With Regards,
Susheel
12-10-2014 06:13 AM
Hello Susheel,
Can you please post the VI?
This way I can modify your VI and verify if my suggestions work.
12-10-2014 06:31 AM
Hii Thierry,
I would like to attach it when i sent the picture format .but it has the problem as listed down in the attachment
Susheel
