It's quite a difficult thing to calculate.
Normally when you do a regression, you're assuming that the X-values are correct and the values vary in the Y-direction.
I think in order to simulate (Calculate I think isn't really possible) the coefficient uncertatinty you need many different data sets. If you have the variance of the indiviual data points, you can maybe try making a fit on many different sets representative of the value variance and from the resulting coefficients estimate the coefficient uncertainty.
Some things are certain though (Which I know from uncertainty calculations in pH measurements)
1) You need multiple data sets, or at least an estimate of how "wrong" your data could be.
2) You mostly need some understanding how the different error sources in your measurement affect the output.
Bear in mind that the calculation of the uncertainty on a single set of data will have zero variance. Only when you have multiple data sets (which you may need to simulate) can you start even thinking about coefficient variance. But then we open a whole new can of worms...
How do you know your "multiple" data sets are representative?
Hope this helps in a little way, and good luck
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
