05-03-2006 11:37 AM
05-04-2006 08:10 AM
05-04-2006 03:23 PM
Dave,
I was a little confused as to what your looking for.
Are you looking to have one set of hardware (1 PCI-6254 and 1 SCC-2345 setup) on one of your four station, let’s call this station A, and then have your 3 other station (B-D) somehow access the hardware on A? And each machine would do there own thing with the hardware on A. If this is the case, I would highly recommend getting 4 setups for each machine.
Or…
Are you looking to have one test machine, lets call it
machine 0, that has the hardware (1 PCI-6254 and 1 SCC-2345 setup) and it
collects data from station 1,2,3, and 4. Each of the tests would be independent
in analysis and data storage. This sounds more of what you are trying to do,
but I want to make sure before going forward. If this is the case, I would also
ask do each of the tests for the 4 stations need to run at the same time, or
are you looking to have say a user pick which station to test, run the test, do
the analysis, store the data, then have the option to start another test on
stations 1-4?
05-05-2006 09:23 AM
05-05-2006 09:35 AM
05-05-2006 09:50 AM
05-05-2006 09:59 AM
