01-09-2012 12:23 PM
rthorpe,
My appologies.. The anti-senility drugs stopped working.
I was reading another post, yet my reply went to this one.
As I wrote my last post, I had not gone back to the top.
Sorry for the confusion.. I'll get my prescription renewed with increased dosage..
01-09-2012 02:32 PM
So you basically only want 1 cluster to have a scroll bar? Then you can place a free scroll bar on the panel and in the event (probably) ... no, no property for that.
To solve it like you want to, you'll have to insert the cluster in a sub-panel. Though i'd still suggest tab control, you can probably find some nice grouping logic if you look again. 🙂
/Y
01-09-2012 02:49 PM
rthorpe wrote:
How do you control the x,y value of the control within the cluster? I've tried doing that with the property "top" but that doesn't seem to work.
Actually, that should work. Just make sure you create the property for the control which is inside the cluster. It would probably be easier if you put another cluster inside the first cluster and put all the other controls into that cluster, because then you only have to move the cluster.
Basically, this methods simulates a scrollbar by moving the content up and down instead of moving the origin.
01-10-2012 01:58 AM
And just because I was bored (LV 8.6).
01-10-2012 03:37 AM
Smart Tst, didn't think of moving all items in the cluster, although it feels kindly of a heavy workaround. Maybe scrollbars is something for idea exchange?
/Y
01-10-2012 04:26 AM
Thanks a lot everyone
01-10-2012 10:01 AM
It's already there, although personally I prefer the second idea, which is tabs inside clusters, but there's no reason we can't have both:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Scroll-Bar-Property-for-Clusters/idi-p/921174
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-clusters-to-have-quot-pages-quot/idi-p/1481862
08-08-2012 01:16 PM
Hi everyone! I have the same problem, i want a cluster with a scrollbar but the example given is created with LV 8.6 and i am using LV 8.5.
Could anyone revert it to my version? Thank you very much for your time.
08-09-2012 12:06 AM
In LV 8.0.
08-09-2012 02:47 AM
Thank you very much!
