How can I insert a non breaking hyphen into a string
  How can I insert a non breaking hypen into a string? Here are the values of a non breaking hyphen
HTML Entity (decimal) ‑
HTML Entity (hex) ‑
How to type in Microsoft Windows Alt +2011
UTF-8 (hex) 0xE2 0x80 0x91 (e28091)
UTF-8 (binary) 11100010:10000000:10010001
UTF-16 (hex) 0x2011 (2011)
UTF-16 (decimal) 8,209
UTF-32 (hex) 0x00002011 (2011)
UTF-32 (decimal) 8,209
C/C++/Java source code "\u2011"
Python source code u"\u2011"
Kaspar
(3,871 Views)
WHere is the string going? Where is it going to be used? If you are putting together a string that's going to be interpretted as HTML, use one of the html codings. If it's an ascii string use the three U8 hex values.
Of course all this assumes that the proigram reading the string knows how to properly handle a non-breaking hyphen.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,840 Views)
  The string is going into a word document
Kaspar
(3,831 Views)
Then insert the three ascii hex characters.
Mike...
LabVIEW Champion
(3,822 Views)
  I tried inserting the 3 chars and it did not work, will have to try something else. Stay tuned for further details
Kaspar
(3,685 Views)
