07-10-2014 01:32 AM
I'm learning C++ and I did this excercise from How to program in C++ Deitel (P7-10) (Salesperson Salary Ranges) Use a one-dimensional array to solve the following problem. A company pays its salespeople on a commission basis. The salespeople each receive $200 per week plus 9 percent of their gross sales for that week. For example, a salesperson who grosses $5000 in sales in a week receives $200 plus 9 percent of $5000, or a total of $650. Write a program (using an array of counters) that determines how many of the salespeople earned salaries in each of the following ranges (assume that each salesperson’s salary is truncated to an integer amount):
a) $200–299
b) $300–399
c) $400–499
d) $500–599
e) $600–699
f) $700–799
g) $800–899
h) $900–999
i) $1000 and over
I solved the problem in C++ but I did this problem in LabVIEW and I solved it too... but i think that my code in LabVIEW could be better so could you check it please?
Sorry I can't to upload my .cpp fileD:!
Solved! Go to Solution.
07-10-2014 01:45 AM - edited 07-10-2014 01:46 AM
http://labviewwiki.org/Case_Structure
07-10-2014 06:24 AM
I dont think you need case structures.
07-10-2014 07:08 AM - edited 07-10-2014 07:09 AM
The Threshold 1D Array also works well in this situation.
07-10-2014 10:05 AM
07-10-2014 10:34 AM
Hey Sandal waht is the sintax to get ranges in the structure case? Or How can I use the ranges in that structure?
07-10-2014 11:37 AM
it only works for integers, but you simpliy type e.g.
