02-13-2006 06:40 AM
02-13-2006 06:57 AM
I Had done it once by using ramps.
For my application, i first plotted/generated a rising ramp, next kept a constant output voltage = high of rising ramp, then after an interval, i generated a falling ramp from that high to a specified low.
can u specify the exact shape of the trapezoid you want to generate? we can suggest better
Regards
Dev
02-13-2006 04:24 PM
02-13-2006 10:21 PM - edited 02-13-2006 10:21 PM
Message Edited by devchander on 02-13-2006 10:23 PM
02-14-2006 05:00 AM
02-15-2006 05:56 AM
Hi Simon,
This particular S series card that you are using, does not have analog output channels.
Like i said before, I used an analog Output channel to generate Trapezoid wave
I am afraid, you cannot generate a Trapezoid wave using any of the DIO's or counters/timers availible on this card
Sorry could not be of more help
regards
Dev
03-14-2006 01:08 AM
03-17-2006 05:28 AM
The original VI was for traditional DAQ.
I have modified the VI to work for DAQmx
but right now, i do not have a suitable DAQ card to test it
So, run it and let me know how it works
Regards
Dev
02-26-2014 09:12 AM
devchander,
Thanks for this bit of code, saved me a some time. Greatly appreciated.
-Wil
