04-07-2007 08:57 PM - edited 04-07-2007 08:57 PM
Lynn's example works just fine. However if you are graphing 1000 cycles over a few hundred pixels, you won't see much.
Here's a small correction to ensure that we retain an integer number of cycles. You may still need another tweak to subtract the first step from the delay. Shouldn't be too hard. 😉
Message Edited by altenbach on 04-07-2007 06:58 PM
09-13-2007 12:52 PM
Hi Altenbach ,
Thank you very much all your help, you are the best programmer in this forum so
I ask for your help once again. I did not know how to contact you so I used
this tread. I have a program to command and read voltage sweep for a Keithley
2400, now I have a Agilent E5272A, but no program. Do you think it may be
possible to convert that one to use with the E5272A?
09-13-2007 12:57 PM
09-14-2007 07:42 AM
Mr. Knutson,
The reason I tried to contact Altenbach is because he helped me in the past with that same program I attached. He understood that I am a scientist with a million things on calendar and no time to learn to do what you guys do or say(As I am shore you don’t have time to learn what I do, Nuclear Physics). Wright now this devise is operating with HT Basic, since it was me the guy that recommended NI for my new Lab. I feel the need to use it. I went NI because at my previous Lab. it worked. I don’t need somebody to tell me what to do because its hard for me to understand, I need somebody to show me what to do. I am not looking for help as a favor, I want help from somebody that helps because it’s his job, I expect to be treated like a client not a regular. Does NI have engineers for this kind of job? Can somebody that works for NI build this program for me?
09-14-2007 08:21 AM
09-14-2007 11:07 AM
09-14-2007 01:13 PM
09-15-2007 09:36 AM
I understand, I apologize for my last reply, after a long night, I let frustration speak for me. I will control my emotions and try to stay in the right forum for now on.
Thanks for you patience and respect.
And you are right, I can do this!
01-28-2014 04:00 PM
If I want to generate a stairecase waveform which has a certain amplitude, say Vpp = 2v. How do I generate this type of form and adjust the step size without changing the defined amplitude.
Chenyu
01-28-2014 04:05 PM
What have you tried so far?
