You do realize you have an entire message body to use don't you?
There are only a couple of things that could be different from installation to installation. One is if a user has multiple DAQ devices. Then the device number might be different. You would use a DAQmx property node to indentify the DAQ devices and the model numbers.
Also, if a 6008 has been used with a different OS and DAQmx base, the device would need to be reprogammed. I don't know for sure if the DAQmx property will even detect a 6008 setup for DAQmx base.
