How can I detect "print completed"?
Hi all,
I want to do an operation like this:
1. read data from file_01.txt
2. put these data in a XYgraph
3. print the XYgraph image
4. load the next data file
5. back to point 2
I used the "Print Panel To Printer Method" in a for loop, but the second file is loaded before the first print is completed, and so on
Can I read the print status? (so I could wait until print is completed before loading the next file)
Any suggestion?
Thanks a lot in advance.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(2,741 Views)
Im not sure, but I guess if you disable the spool function of your printer (in XP: advanced printer properties/ print directly to printer) Labview will wait until the print job is done.
Kind regards,
(2,733 Views)
The problem is that I can't modify that option because I'm connected to a shared printer, and I haven't the administrator rigths.
Vix
Using LV from 7
(2,715 Views)
Could you post some code or a picture of it?
I just made a simple example which seems to work properly.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,713 Views)
You're rigth, but the problem is that the Front Panel is updated quickly, so in the graph I only can see the last data set (even if the documents in print queue are correct - i.e. all different -).
I'd like to see the first data set, so I can type the correct name for the pdf file i want to obtain, then see the second data set and type the proper pdf file, and so on ...
Probably I made some confusion before, but I need to print both on an a physical printer (which is a shared one) and a virtual printer (PDFCreator) to obtain a pdf file.
I made experiements using Standard Report, but the image quality in the pdf was really poor.
Message Edited by vix on 07-21-2005 12:14 PM
Vix
Using LV from 7
(2,708 Views)
But you have the possibility to control the sequence using the dataflow and you can use a sequence structure in addition to that. So as you want, can have each operation in a separate frame of the sequence structure. I did it this way too in the example.
Using LV8.0
(2,698 Views)
