How can I convert an ac waveform to dc in Labview?
I started out with an AC waveform, and I rectified it. I think that the next step is to add a capacitor. Is this correct? If so, how can I implement a capacitor in Labview? If not, what should I be doing?
(3,584 Views)
With some funky math.
I don't understand what you are trying to do.  Are you trying to build a circuit?  Did you aquire a waveform and are now trying to perform some measurement on it?
GCentral
(3,573 Views)
Wioth rectifiers and caps, it sounds like you are using Multisim and not LabVIEW. You should be posting to that board.
If you are actually using LabVIEW, then all you probably need is the Basic Averaged DC-RMS function.
(3,563 Views)
I have the same doubt as well. Please can anyone send a snap of the rectifier code in labview
(2,442 Views)
Hi chathura,
what are your "doubting" about a nearly 7 years old thread?
Simple math:
or this:
(2,432 Views)
