12-22-2005 09:20 AM
01-04-2006 10:55 AM
01-05-2006 07:28 AM
Christian - I am not quite following you. I try to put the shared library into the installer properties and I am getting a message about the Labview library not having a common path as the projects library or someting like that. Can you be a little more specific as far as how I should actually perform the two steps you were talking about?
Troy
01-05-2006 08:49 AM - edited 01-05-2006 08:49 AM
Hi Troy,
Sorry, but I think I missundersood you.
I think you have to deploy the library programmaticaly by using the Application Control functions (OpenAppRef, InvokeNode)
I didn't test this but the following picture shows how to start:
Kind Regards, Christian
Message Edited by Christian_M on 01-05-2006 09:11 AM
01-05-2006 09:13 AM
