11-24-2005 04:04 AM
11-24-2005 04:17 AM
An interesting thought, but it might be a little tedious if the additional warning case was always there by default - you'd probably want it as an "right click menu option".
Of course - it's probably just as easy to add a sub case to the "No Error" case to handle warnings.
Greetings from the U.K.
Mark H.
11-24-2005 04:21 AM
11-24-2005 09:09 AM
11-24-2005 09:14 AM
Yes, this was not bad indeed. But therefore the boolean control in the error cluster should be replaced with a tristate control.
I can't exactly remember where, but there is a link, where you can post improvement suggestions.
Maybe this could be a new feature in LV9.0
Thomas
