06-10-2015 05:34 PM
I'm using Labview 2013 SP1 with the Microsoft Report Generator and I can't figure out how to write one DP number to one specific cell on an Excel spreadsheet. I have no problem writing arrays of numbers to specific ranges of cells, formatting cells, writing titles, using templates, everything I need except being able to write one number to one specific cell. All the vi's that write numbers seem to demand 2D arrays for inputs. I must be missing something, but I think I've gone through every vi in the MRG pallette and found nothing.
Any help/examples greatly appreciated.
Solved! Go to Solution.
06-10-2015 05:57 PM
06-10-2015 06:08 PM
06-10-2015 08:02 PM
... and you probably know that the easiest way to do this is with Build Array, twice.
Note the lines getting "thicker" going left to right.
06-11-2015 09:11 AM
Thanks to all who responded.
A "bogus" array seems to be the way to go. Odd that with all the power of MRG such a simple task requires a workaround. Oh well, the important thing is that it works an I'm sure this will. The double Build Array is clever, I probably would have gone for the Initialize Array, but the double is easier.
Thanks again....
06-11-2015 10:56 AM
It will help other readers of the Forum who might have the same question to ask if you would mark the Solution.
BS
06-11-2015 12:46 PM
Done, thanks.....
