How Programatically Change Limit Alarm in DSC
Hi
  How Programatically Change Limit Alarm (Hi,Hi Hi,Lo,Lo Lo) in Tag Configuration Editor in DSC.
(2,651 Views)
You can't really change the tag configuration file with a labview vi. You can use the tag attribute vi's to modify the alarm values, but these will need to be set each time the computer is rebooted. If you need to change the alarm value for a large number of tags, export the configuration, modify it, then reimport the config into a new file.
(2,646 Views)
