10-22-2012 06:43 AM
Hello!
I'd like to ask a question;
I have a VI that are doing some calculations, depending on the results, the data are updated in a cluster, the user is seeing updates cluster on the front panel. The cluster is an output of VI.
When I use the VI in the main, I can’t see the updates of the cluster, I only can see the final value.
I've also tried to use global variable, but I can not display them on the main VI.
How I can see cluster updates of a VI in the main?
Thank you very much!
10-22-2012 06:53 AM
What do you mean by updates here?. How you are updating the cluster?
10-22-2012 07:33 AM
Attached the files. I need run the main and see the changes in the cluster in the same window. Depending on the values of the cluster, I'll do something different in the main.
I hope to explain well.
Thanks.
10-22-2012 07:45 AM
If I am correct you want to display all the values updating in the cluster from subvi to the main vi.... If this is the thing, try using the reference of the cluster in the main vi and pass it to the subvi.
Rajashekar
10-22-2012 08:02 AM
yeah, that's what I need 🙂
Do you mean to pass the reference to use as input of VI? or how i can do it?
10-22-2012 08:09 AM
Yes, pass the reference of the cluster (present in the main vi) as the input to subvi (vi called inside main vi).
Rajashekar
10-23-2012 01:43 AM
it doesn't work. Any other help, please?
10-23-2012 01:45 AM
Can u convert the vis into Labview 7.0 and post it so that i can check it.
Rajashekar
10-23-2012 02:05 AM
Sorry, only let me to convert into Labview 8.0 😞
10-23-2012 02:07 AM
K....what is the problem u r facing.....
