Highest speed for a loop in the microprocessor of my CRIO?
Thanks for your help for improve the programation.
But maybe my problem is much more basic:
For be sure I developed this simple program(I attacht it) in the microprocessor, and even with this loop im not able to achieve loop iteration times lower than 1 ms (1 KHz).
What do you think about this? Looks like a limit of the processor..
Regards
Message 11 of 13
(351 Views)
Hi Alvaro,
are you sure about that? How fast can you watch your VI executing? 😄
The problem with pictures is: we cannot see what you have set as value for the loop timing. So just some comments:
- The timer value is given as U32, so the result of subtracting current timestamp with previous is either zero or one millisecond...
- Setting small microsecond values to wait for will not change the behaviour of the timestamp function...
Hint:
Try the TimedWhileLoop with a timing source of 1MHz (or whatever your cRIO supports). Now try to execute that loop with 2kHz or 5kHz and watch the "late execution" flag...
Message 12 of 13
(336 Views)
So, if I understood well, I cannot measure the timeloop time with the method of the clock and the shift register when the loop times are the order of microseconds.
Im not a experienced user with labview and CRIO, I dont know exactly what do you mean with a timming source of 1 MHz, and wacth the late execution flag for know the time loop period.
When I check the loop times I always do it using the method of clock and the shift register.
I also attach the the calculation SubVI with the method that I use for measure the time loop, this time is always higher than 2000 micreseconds, even in the processor of the computer, I think that could be a problem about how I measure the loop time(clock and shift register).
Thanks a lot
regards
Message 13 of 13
(321 Views)
