I am trying to get the highest peak in blocks from a signal. I wired the diagram below from the http://www.ni.com/white-paper/3770/en website. Figure 7. Using the Waveform Peak Detection VI to process a signal that is broken into several blocks
I can't seem to figure out how to get the highest peak from each block and make it save the peak into a display that is the highest peak for that block and repeat until the signal is over. Can someone help me figure out the pseudo code or anything that can get me started. Any help is appreciated
