07-12-2005 07:45 PM
07-12-2005 07:58 PM - edited 07-12-2005 07:58 PM
Hi Liermann,
You can use Save with Options -> Remove Diagrams. This removes the block diagram from your vi's. Make sure you save the original vi in another location as a backup in case you want to do further work on it.
Hope this helps.
Message Edited by DavidT on 07-13-2005 11:59 AM
07-12-2005 08:51 PM
If you want to remove the block diagram and the front panel you have one other option. Build the VIs into an executable, but with a couple twists. First change the name of the executable you're building to have an extension of llb instead of exe. Second, add the VIs as dynamic VIs not top-level. Third, on the VI Settings tab change the settings for each VI to remove the front panel.
When you build this you'll get an llb with VIs in it that you can call and link to as you would any other VI, but there's no front panel or block diagram. OK, trade-off: When you remove the front panel you also lose the Icon image. Hence, you can place these VIs on a block diagram but they will all look the same. The only way to distinguish them is to show the label so you can see their name.
This will work, but I'm not sure what the point is...
Mike...
