01-04-2006 04:12 PM
01-04-2006 04:16 PM
01-04-2006 04:30 PM
01-04-2006 04:43 PM - edited 01-04-2006 04:43 PM
Message Edited by altenbach on 01-04-2006 02:59 PM
01-04-2006 08:17 PM - edited 01-04-2006 08:17 PM
Hi pallen,
This is probably overkill, but these solutions are fun to do...
Building on Altenbach's idea, but without need for a while-loop...
cheers!
Message Edited by Dynamik on 01-04-2006 08:17 PM
Message Edited by Dynamik on 01-04-2006 08:22 PM
01-04-2006 08:37 PM
Dynamik, your "version2" is a bit better than the original attachment, but you still should replace the %7x with a %x to get rid of the leading spaces for small numbers. 🙂
01-04-2006 09:21 PM - edited 01-04-2006 09:21 PM
Doh! - you're right!
(so many edits! i need to figure-out how to use the smilys next to parens...)
Message Edited by Dynamik on 01-04-2006 09:22 PM
Message Edited by Dynamik on 01-04-2006 09:29 PM
01-05-2006 01:34 AM
Obviously, Altenbach is right, and I probably wouldn't have suggested that as a solution, but I had to leave the computer unexpectedly and didn't complete a full answer. Thanks, Alten.
@altenbach wrote:
Additional additional Note: 😉 I would recommend to stay away from the text property method. I don't like code where the outcome depends on cosmetics such as the numeric formatting of an indicator. Even worse, the code will break once you delete the indicator. Property nodes are also relatively expensive in terms of CPU (this is not an issue here unless this happens in a fast, long running loop).
01-05-2006 07:52 AM
