11-06-2014 08:34 AM
forget how bothersome linking VI's is!!
11-06-2014 08:37 AM
Zip all the VIs and attach one file.
Lynn
11-06-2014 08:40 AM - edited 11-06-2014 08:41 AM
Hi dhanna,
in your array you defined a HEX number like "6065710800000699" in an I64 array.
In your connect.vi you defined an I32 number which CANNOT hold that number. Thus it gets coerced to I32-MAX of 0x7FFF.FFFF…
Always use the correct datatype. Create constants by right-clicking the corresponding terminal…
11-06-2014 08:44 AM
think whats needed is now there?
11-06-2014 08:50 AM
11-06-2014 08:54 AM
shouldnt matter about the representations as all i've done is change the original array to have that new hex code (which represents a different board) in. as opposed one of the boards it had (606578000000000E)
11-06-2014 09:00 AM
Hi dhanna,
I can't comment on what you changed and what you didn't changed.
All I see is a coercion dot and a datatype mismatch!
I suggested a possible solution. You might look for other solutions if mine is no option for you…
11-06-2014 09:27 AM
got it!! one of the data types had to be 64, so kudos!!
the other mistake was i mistyped a number into my Hex code........ 😞
thanks guys, shall give kudos for our help
