10-21-2015 06:07 AM
Hi there. I am trying to create a 3D surface plot of the following parametric function:
z(x,y) = xy^3-yx^3 over the domain from -2<x<2 , to -2<y<2
I have created the block diagram as shown. However, upon trying to plot the graph I recieve the error " You have connected two arrays of different dimensions. The dimension of is 2, and the dimension of y vector is 1. I am new to labview, and I am not sure how to resolve this error. Is there a way to cluster my array to produce a plot and remove the error? Any help greatly appreciated. Thanks
Solved! Go to Solution.
10-21-2015 06:23 AM
10-21-2015 08:24 AM
Thank you
