09-19-2012 12:15 AM
Hi guys, I really need your help. I am currently creating a program where I can select the button keys (A-Z and 0-9) from three numeric and use keyboard in order to turn the 3 individual respective booleans on to light up. I am working for a while now. Here's my program::manvery-happy:
09-19-2012 12:26 AM
Please post your code in 2009 version.
09-19-2012 12:31 AM
Here it is the 2009 ver:
09-19-2012 12:40 AM
You have to be more specific about your question what exactly you want to result?. Is it just lighting the booleans? what condition they have to be enabled and disabled?. Please explain
09-19-2012 01:03 AM - edited 09-19-2012 01:16 AM
There are some basic misunderstandings.
I don't understand under which conditions the booleans should light up? Can you explain?
09-19-2012 01:27 AM - edited 09-19-2012 01:30 AM
Sorry for not being specific. I am still a newbie in this. The program will run like this. When I select 'a' from the numeric list and i press on the keyboard key 'a' , the unlit boolean will light up. When i press 'a' again, the lit boolean will unlight. While the program is still running, i still can select different key like '5' and the different key '5' will still toggle it when i pressed it. The three numeric and three booleans act accordingly. Here another similar program i also worked on it but it can only use the other keys. I need to select A-Z and 0-9. I just need it to light up.
09-19-2012 02:11 AM
@Tissue wrote:
When I select 'a' from the numeric list and i press on the keyboard key 'a' , the unlit boolean will light up. When i press 'a' again, the lit boolean will unlight. While the program is still running, i still can select different key like '5' and the different key '5' will still toggle it when i pressed it..
Try something like the attached (LabVIEW 2011).
Pressing one of the keys (case insensitive) will toggle the coresponding boolean. Changing the selection will clear all indicators. Modify as needed.
09-19-2012 02:30 AM
09-19-2012 02:55 AM
Thanks a lot , Buddy!!! I love you
