Help needed, with different data types/terminals
I get the orror of different connecting two different types of data terminals. I know there is a context help which I have been viewing and also other posted topics on this matter. I still cannot figure out how to get the XY graph to work with my configuration.
I'll post a screenshot for a more specific description of the problem. Basically a loop that will generate a number from 1 to 500 on the x-axis while generating the 10 logaritm of x as Y-axis.
(2,699 Views)
Please do not attach a picture of your code, but rather attach your actual VI.  We cannot see a picture so clearly, we cannot "try it ourselves", we cannot "edit it so we can figure out what you are doing".
(2,690 Views)
Accepted by topic author Chrisus86
The XY Graph does not take 2d arrays in the cluster.  So first get rid of the Build Arrays.  Now I assume you actually want all of those integer values, so use another indexing tunnel to output them as an array.
GCentral
(2,665 Views)
Use this as example.
XY graph.png/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,611 Views)
I got rid of the build arrays and i branch wired from the upper terminal to a third which now represent the new X-axis in auto-indexen tunnel, as you suggested.
Thanks alot!
(2,584 Views)
