I don't have a VI for you, but I'll try to give you some ideas.
Of course, first you will need to use DAQ VIs to acquire the data. You will probably have a loop with one scan process per loop iteration. In that case, just put a chart inside the loop and the new data will be added to the chart. The data will be plotted starting at the last scanned x-axis point, and the plot line will continue from the previous y point. If the new scan doesn't start until the user presses a button on the front panel, then you should use event driven programming. I have included a simple example that will plot new data after the user hits a Boolean. The new data is added to the chart.
You might want to search on google for LabVIEW and xps to see if someone else ha
s implemented some VI to use with xps.
Zvezdana S.
