08-24-2016 03:54 PM
hi Folks,
I wrote that basically looks for broken vis in a folder and reports them. it works great and does what i need it to. i made an exe to distribute it and built the exe. when i run the exe and ask it look at the folder containing the broken vis, it basically reports all the vis as broken even though there are many which arent broken. the exe and the VIs to look for are in different folders. I'm not sure why this is happening. your inputs are most appreciated!
Santosh
08-24-2016 07:44 PM
How are you checking to see if the VIs are broken? Supplying code would help us help you diagnose this issue.
08-24-2016 09:24 PM
attached..
08-24-2016 10:03 PM
Thanks for attaching your program. I'm having a lot of trouble running it -- LabVIEW doesn't seem to know how to process a file with the .jpg extension. Could you please attach a file with the extension .vi, which is what LabVIEW expects? This way, I'll know that I'm working on exactly the same code that you describe ...
08-25-2016 01:37 AM
haha..very funny 🙂
