HOW DO i CREATE AN ICON FOR AN APPLICATION
Hi
How do I create an Icon for an application and how do I load it up ?
Thank you.
(2,521 Views)
Just to clarify.
I want to know how to create an icon for an executable?
Thank you.
(2,513 Views)
Have a look at this thread for some advice on creating custom icons.
http://forums.ni.com/ni/board/message?board.id=170&message.id=17823
To use add your icon to your application, in the Application Builder, select the Application Settings tab, check the Custom Icon tickbox, and navigate to your icon.
Hope this helps.
(2,509 Views)
If you already have an icon file (.ico) and just want to include it in your executable, then look at the previous post. If you want to create one, go to File >> VI Properties >> General. There, hit the Edit Icon button, and you can create your own custom icon for this VI. Once you're in the Icon Editor, you can also import in images from files. Go to Edit >> Import Picture from File. Hope this helps!
Jeremy L.
(2,474 Views)
