08-28-2013 03:08 PM
Hello all,
I am actually writing my own drivers right now. I want to use PULSE to do some measurement,but I just found out this SCPI command I am using
":SOURce[1]:FUNCtion:SHAPe <DC|PULSe>" is not supported by the instrument.
What should I do?
Solved! Go to Solution.
08-28-2013 03:35 PM
08-28-2013 03:36 PM
@huskerli wrote:
Hello all,
What should I do?
The instrument has the ultimate say. If the command is not supported, it is not supported. I don't know what you expect we can do about that.
08-28-2013 03:37 PM
@DennisKnutson wrote:
Use a command supported by the instrument or use a instrument that does support the command.
I have no idea what instrument you are trying to use or where you got the command. Both of those are important details.
He has another thread open about this same topic.
http://forums.ni.com/t5/LabVIEW/agilent-SCPI-commands/m-p/2539162
08-28-2013 03:49 PM
I am using Agilent B2901A and I get the command from the Agilent B2900 Series SCPI command reference page 325.
I just do not get it since the instrument has that functionality and I been manually tested successfully why there is no SCPI command for that?
08-28-2013 03:52 PM
I think I must missed something really important and wanna someone who know this can points out me
08-28-2013 04:39 PM
08-28-2013 05:08 PM
Looking at the docs you provided, this command is listed under Conventional commands not supported by B2900. So I guess this function is not supported. If an equivalent command exists, you will have to find it in the docs you provided. You may have to experiment a little.
08-28-2013 05:23 PM
