Background: I have an event based state machine (two state machines ) which concurrently reads data from 2 sensors and writes to a text file. The sensors are IMU 500 and an INTRANAV indoor navigation position sensor.
I have also developed 2 separate VI's to read data from each sensor and it works fine(just to check if it is working)
Problem: integration of these 2 sensors in a single VI causes error with serial communication using VISA while read and write
I have verified the COM port with NI Max and device manager.
I'm attaching the screen shots with error and the actual VI
Cheers
