08-30-2005 11:15 PM
08-30-2005 11:28 PM - edited 08-30-2005 11:28 PM
Message Edited by LV_Pro on 08-31-2005 12:30 AM
08-31-2005 12:42 AM
You were saying my test fixture is a floating signal source, right?
If my power supply is reference to a system ground, does my test fixture in the block diagram ground would be what?
It would be just a negative terminal refer to the positive terminal or it would be referenced to the system ground?
I don't have my digram right not. But my diagram contain some capacitor connected to ground just like this. The symbol
is a ground symbol and it is like one vertical line with a few horizontal line.
You were talking about ground return, did you means a negative terminal point to the positive terminal for the common ground point,
not the system ground reference to the earth, right?
08-31-2005 11:16 AM
08-31-2005 12:14 PM
If you intend to plug more than one instument, make sure they have a common "ground". Especially multiple power supplies.
The earth ground is to protect you from electrical shock hazard. And may be used as an analog (or part of) reference for ground. I would certainly make sure instruments are properly grounded as per the manufacturer's recommendation..... even if not recommended.. It is surprising how much potential difference (especially DC) can exist between a virtual ground and earth ground.
JLV
08-31-2005 12:21 PM
08-31-2005 12:56 PM
09-05-2005 10:02 PM
Hi
Thank you for your help!
Here is my diagram.
1) Is my test fixture a floating signal source in this case by looking at this diagram?
2) Is my power supply also a floating signal source in this case?
09-06-2005 12:50 AM
09-06-2005 11:38 AM
