07-29-2015 12:48 PM
07-29-2015 05:33 PM
You should still have access to the examples in the Help>Find Examples menu, these are all installed directly onto the PC with LabVIEW install.
That in mind, looking through there if you look at the:
Continuous Serial Write and Read
XY Graph Data Types
Should be enough to jog your memory.
String seperation is easy enough with the Scan from strin given that you know how the data is to be presented.
07-29-2015 08:40 PM
Thanks.
Looks interesting but didn't get far...
Error -1073807202 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->Continuous Serial Write and Read.vi
LabVIEW: (Hex 0xBFFF009E) VISA or a code library required by VISA could not be located or loaded. This is usually due to a required driver not being installed on the system.
jh
07-29-2015 09:45 PM
Have you installed NI-VISA?
07-29-2015 10:00 PM
Thanks for posting.
I did not. I did not see any obvious way of doing so and assumed it wasn't available with the trial version.
thanks,
jh
07-29-2015 10:15 PM
What version of LabVIEW are you running?
07-29-2015 10:21 PM
Evaluation version 14.0f1
07-29-2015 10:32 PM
07-29-2015 10:40 PM
Thanks, I didn't know what to look for or where to look for it.
I was trying run the Continuous Serial Write and Read example that ogk nz recommended. The only instrument attached is the FTDI USB-RS232 converter I menitioned in my original post.
jh
07-29-2015 11:09 PM
