Graphic
As you can see there are 3 attached files. If you run this code you can see that it's appearing three lines on the first graph and one line on the second graph. My goal is to obtain all lines on the same gragh. How can I do it?
(2,123 Views)
Accepted by topic author Mark87
Just wire them all into the same cluster array.  If you've tried that and it didn't seem to work check the plot color.  Plot 10 seems to default to white so it's not visible.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(2,078 Views)
Thanks. The question is that plot 10 is not visible! 😄
(2,058 Views)
