08-01-2011 10:34 AM
Well, my financial advisor tells me that it takes time...
08-02-2011 01:12 AM
hex_cro ha scritto:
Thanks, but...my sequence is linear, I think a state machine is not necessary...
So I think you can easly switch from your large flat sequence to sequence of SubVI linked by error (it's not necessary to check or control the error, simply pass it through the SubVI), in this way you have a linear solution that take less space in the graph editor. You simply have to change each case with a SubVI which wraps the code of the case..
Regards.
