11-01-2015 06:03 AM
I am looking for a way to select the propertyes of a cursor in a separated custom dialog VI. I cannot find the picture ring controls for some propertyes as cursor style, point style, etc... Is there a way to get this controls from labview, or at least the images of each one to make a custom one?
11-01-2015 08:11 AM
Hi Antonio,
simple solution:
In your "main" VI you create a small graph and show it's cursor palette. You use this palette to have the user set cursor properties. Then you just read the properties and use them to set the properties of the cursor/graph in your "separated custom dialog VI"…
Why don't you enable the graph palette in the dialog VI? It's a dialog, where the user usually have access to FP controls!?
11-01-2015 08:35 AM
11-01-2015 08:38 AM
Hi Antonio,
I still don't see why you can't use a standard graph - you may even hide the graph display itself and only show the graph palette…
If you want to create a different solution: use some picture rings with some self-made images!
11-01-2015 08:41 AM
11-01-2015 08:43 AM
11-01-2015 08:48 AM
11-01-2015 08:59 AM
