Good Ol' Boolean Logic Question
These are like riddles to me!
I want "if x is false and y is true return true. Otherwise, return false."
Here is what I came up with.
Is there a better way?
(2,138 Views)
Accepted by topic author GregFreeman
You can use a compound node and invert the appropriate inputs and output. (See also).
(If the output is just wired to a case structure, you could simply flip the content of the two cases and skip the invert)
(2,132 Views)
It's actually going to a boolean to number function then to a ring control, but this is what I was looking for. Thanks.
(2,129 Views)
