04-19-2017 10:00 AM
I am trying to work with this example vi
http://www.ni.com/example/30992/en/
It's used to log in to a gmail account and send an email to a recipient via labview. The gmail.vi however gives me an error... something about a .NET? I'm not really sure how to update the vi to make it work. Any advice/solutions? Thanks!!
FYI I want to use it as an alert/status alert for a pressure gauge I am monitoring via labview.
04-19-2017 11:26 AM
You don't give us much to work with. What is the error? Where does it come from?
That being said I'd guess the most common issue is you need to enable less secure apps from logging into your account to send emails.
https://support.google.com/accounts/answer/6010255?hl=en
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-19-2017 11:32 AM
Here is the vi and the error. The vi is also available in the previous link.
04-19-2017 12:04 PM
Yup secure connection issue for gmail was posted here.
https://forums.ni.com/t5/LabVIEW/ERROR-Sending-email-on-labview-Gmail/td-p/3154411
Which has the same solution which is to enable less secure apps on the account.
04-19-2017 01:46 PM
I have already enabled that setting on my gmail account, but am still getting the same error.
04-19-2017 03:29 PM
Try the version that I have attached below. I have been using it for years with no issues.
And from that error message, it actually looks like you are not using the correct port or not accessing a secure connection. What port are you using?
