06-09-2015 12:55 AM
Still i am facing some issue with user event handler. Could you tell me how to do with global variable?.
Regards
Punith
06-09-2015 01:28 AM
HI ALL,
Here i am updating the subvi and main vi which tells what actually i need kindly tell me how to solve this.
Regards
Punith
06-09-2015 03:07 AM
There are missing a lot of sub-vi's. It is nearly impossible to give any advice without these sub-vi's.
But there are some part I can comment on:
06-09-2015 03:10 AM
subvi-6 is just taking input and giving hex output.
subvi-3 is actual subvitest1.vi which is one what i have shared.
Dont worry about subvi-6, it is just giving hex string output.
Regards
Punith
06-09-2015 03:21 AM
If we need to help you, the best way is to share ALL the code.
Get a part of the code does not help us in figuring out what you are doing and helping you.
It is hard to navigate through code when there are parts that is missing and parts that has been renamed but not relinked.
06-09-2015 03:24 AM
OK Here will subvi-6
06-09-2015 04:52 AM
OK, just looking at your main VI:
Why don't you describe to us, what you're trying to achieve, i.e. the bigger picture and we can give you some pointers as to how to get there. I would bet 100 kudos that it doesn't involve an in place structure. So: What should your program do? What are you trying to achieve with the in place structure?
06-09-2015 05:00 AM
Just some comments to the "Untitled6 (SubVi).vi"
06-09-2015 05:12 AM
Yes in later section i will remove in-place structure.
1. untitiled subvi is taking string as input and converting to hex string and then sends to tcp board which intern returns string which i am converting to hex string and then i passed this string to recursive subvi.
2. in recursive subvi i do some calculate on string and output i need to pass to string indicator whic is main.
3. if recursive function call again i will do some manupation on output hex string and again i need to update the main indicator.
Regards
Punith
06-09-2015 05:27 AM
i stuck with this from 2 days, kindly suggest me.
Regards
Punith
