Hey all, Has anyone had a case where when coding you open your code and lets say even click on a global variable which then converts/turns/does something to turn into a shared variable? Why I ask is that i'm trying to insert a PID loop to an older code (LabView 2011). Before I left for the day yesterday i could move the existing global variables with no problem. Today when I got into the office was a different story, seems like any time I click on the G.V. it switches to a shared (It first started when I moved a G.V. into a case structure, which was also the first thing I did today). I tried digging around to see if the G.V. Vi.'s were manipulated at all but was unable to find anything. I also hadn't saved any work while the G.V. were preforming normally, just essentially testing different solutions and closing out of it.
