06-07-2012 12:24 PM
Running Windows 7 and getting this error 5 when trying to write to a file
It seems such a simple thing to do, I have used the write to file on other projects with no issues but
on this Win 7 machine ( and another also) it just doesn't want to play
Solved! Go to Solution.
06-07-2012 12:49 PM
What does the error message say? "File Already Open." That tells you everything you need to know. You still have a reference open.
06-07-2012 01:03 PM
In the future do not post Powerpoint presentations for a screenshot. PowerPoint is a proprietary format. Attach a PNG, JPG, or GIF (in that order of preference). DO NOT POST BITMAPS. And do not change the filename of a bitmap to get around the ban.
06-07-2012 01:06 PM
Sounds like you are trying to view the file with another program while trying to write to it.
Also, please post pictures as a PNG or JPG. Viewing images in a power point or word document is annoying.
06-07-2012 04:06 PM
I believe the OP pasted his screenshot into power-point.
06-07-2012 04:43 PM
The reason the file was in a .ppt was because I did a screen snapshot and had to paste it into something.
I never knew about the Powerpoint thing.
The file was not open in anything, I canged the file so it left the default location that LV puts them in to a memory stick
and that worked fine and then I made a new folder on my C drive and that worked also.
I don't understand why it wouldn't work on the default Folder but I don't really care about that anymore.
Maybe just a Win7 thing
06-07-2012 09:41 PM
@Nick5405 wrote:
SpoilerThe reason the file was in a .ppt was because I did a screen snapshot and had to paste it into something.
Is there a solution here?
