Getting Started with Swept Sine (DAQmx) Multiple Response Signals
I've been using the modified version of the Getting started with swept sine.vi for multiple response signals
https://decibel.ni.com/content/docs/DOC-24474. Program fully suitable.
However, I am facing with three issues :
1) The edits are highly non user friendly (horrible for 6 multi-channel already), and quite long to perform.
2) Would there be a way using for loops to have a more compact and flexible way to use FRF? (Calling 6 times the same program in a similar structure does not quite seem like a smart move yet I'm relatively novice in LabVIEW).
3) Be able to set the number of channels somewhere in the software, and automatically have the software to be able to cope with this? (aka if 20 multichannels are needed, no need to modify the code?)
It's probably going to be a lot of work to get there, all I'm asking for you guys is to point me in the right direction and suggestions,
Cheers,
Kentmey
Kentmey
(2,132 Views)
duplicate post, continue here
(2,128 Views)
