03-19-2015 09:57 AM
All,
I've been having no end of grief trying to connect NI MAX to my remote cDAQ 9134 (Linux RT) through a cellular gateway (firewall/NAT). I currently have all the ports I think are even slightly MAX related forwarded to the IP of the cDAQ. The IP address assigned to the cellular gateway is part of my corporate network, i.e. this is not a remote private IP but instead an IP on my WAN.
Currently the following ports are forwarded:
The web UI function works across this arrangement, as does SSH - but not MAX.
NI MAX will find the device at first, but then it transitions from connecting to a red-X icon... but not before discovering the serial number and a few other parameters (not all).
I need this to work so I can remotely deploy new software modules to the cDAQ 9134.
Has anyone accomplished something similar in the past? Am I possibly missing a port?
Thanks and Regards,
Jeff
03-20-2015 03:50 PM
Hello Jeff,
As long as you have unblocked all of the ports pertaining to NI MAX in this White Paper:
http://www.ni.com/white-paper/12402/en/
you shouldn't have missed anything. Is there any way to connect it locally, or does it have to be over the network?
04-07-2015 02:51 PM
It needs to be over the network.
As you can see from my listed ports, all ports pertaining to NI MAX (and many that aren't explicilty stated) are forwarded.
Ultimately I believe that the issue is that NI MAX is incapable of working with a high-latency (<1,000ms) network. After spending a lot of time with it and NI support it clearly was never designed to traverse a network and really is a LAN-based tool. Just a word of caution to other users.
06-07-2022 09:02 AM - edited 06-07-2022 09:03 AM
Hello, have you managed to use NIMAX through NAT? I am experiencing the same issue and I haven't found a workaround.
