Get array elements
I have a VI that simulates the heatcycling of an oven. So far I was able to capture the powerconsumption and the temperature, everytime the heating starts or stops (with a lot of help from members of this board....).
Now I would like to do the following:
When the block temperature gets to a certain value (constant in the vi) the vi should check if the oven was heating or not. If the oven was heating at that time, I would need (lets say) the values of consumption and temperature at counter n-1 and n+1.
If the oven was not heating at that time, I would need the values at counter n+2 and n+3.
The counters here are only examples. I've tried a lot of things already. i.e. compare temperature > if true > get index of array, etc.
Anybody out there with a good idea???
Thanks a lot.
(I already found this forum really useful)
The German Guy
The German Guy
(2,466 Views)
I think I have a solution, problem is I don't know how to post an
attachement to this newsgroup....Send me an email and I will reply with
an atached file
BR
/Sture
> Thanks a lot.
> The German Guy
> Energy_consumption_simulation_one counter2.vi:
> http://forums.ni.com/attachments/ni/170/204685/1/Energy_consumption_simulation_one counter2.vi
(2,442 Views)
Hello Sture,
Thanks for the help. I found my mistake late on Friday evening. The case structure has a comparison attached to it which checks, when the temperature hits a given value (in this case it was 80). Unfortunately, I've set the counter of the heat-simulation to something in between 0 and 1 (which is added every time the loop goes). The value I had chosen made my heating so, that it never exactly hits 80. So there is never a true for the case. I changed that to an element, that lets me set an upper and lower limit. Now it works. If you anyway want to take a look at it, I've attached the vi again. (May be somebody else can use some of the ideas too).
Thanks anyway,
The German Guy.
PS.: To send an attachment, you only have to hit the grey button marked "Browse..." underneath the posting-box you're writing in. Then you can easily choose a file on your hard drive.
The German Guy
(2,392 Views)
