Get NI RMC 8355 motherboard and CPU serial number programmatically
Hi all,
I need to read the motherboard or CPU serial numbers of the NI RMC 8355 programmatically.
I have tried to use "wmic baseboard get serialnumber" comand in cmd, but it returns "0123456789", which apparently is not a valid serial number.
Does anyone have any idea how I can read that information?
Is there any toolkit or LabVIEW VI which will do that job.
Thanks in advance.
(3,313 Views)
Hi Gevorg,
You should be able to accomplish this using Active X controls or property nodes...I'd start with the Active X.
Kristen M
Automated Test Product Marketing Engineer
(3,243 Views)
Hi Kristen,
Thanks for your answer. I couldn't get the data neither by invoke nodes nor by property nodes.
Do you have any other ideas?
Gevorg
(3,080 Views)
Gevorg,
This is a Windows property that you can access the same way you would with a desktop PC, using the 'wmic baseboard get serialnumber' command.
http://www.windows-commandline.com/get-serial-number-for-ram-motherboard-hard-disk/
Kristen M
(3,051 Views)
Kristen,
As I mentioned in my first message, the 'wmic baseboard get serialnumber' command returns "0123456789" as  a serial number. But it is not a correct result. I tried the same command on several desktop PCs, and some of them returned the serial number, and the others did not.
Gevorg
(3,022 Views)
