09-01-2016 03:46 AM
I am new to LabView and want to generate specific output signals. Everything >1ms works fine but is it also possible to generating pulses, with a pulse width of for example 500µs?
I am using the NI cDAQ-9178 with a "NI9474 DO24V Source High Speed" module.
Thank you
Chris
09-01-2016 03:54 AM
09-01-2016 03:56 AM
Where can i find it?
09-01-2016 03:57 AM
09-02-2016 12:37 AM
Hello Chh2807,
attached a simple way i have done this
if only a PWM with frequency change is needed i also attached a example.
09-07-2016 08:13 AM
Thank you very much for your examples. Now i have to try to understand that if this works for my needs. Thank you!
regards,
Chris
01-16-2019 03:30 PM
Can someone explain how to modify the Generate DI with Time Continuous.vi to generate a single line pulse? I keep getting an error indicating that the number of lines in the data for a channel does not match the number of lines in the channel. Please any assistance will be appreciated.
