Reply
Generating a flicker signal VI?
Hello all,
I'm currently creating a program which creates several tests concerning Power Quality with a Daqmx PXI-4461.
First of all i would like to say that i have no problem generating or reading signals with the Daqmx.
I'm currently at the point where I want to generate a flickering squarewave signal (flickering = small voltage dips over time) with the Daqmx, and was wondering if there was an example somewhere on the web that lets me insert the flickerfrequency and % decrease compared to the RMS value
Like a good professor of mine always said, its better to edit an excisting example then to start from scratch!
Dennis
Message 1 of 2 (218 Views)
Reply
Re: Generating a flicker signal VI?
Hello Dennis
I didn't directly find directly usable code, but I did find something else:
https://decibel.ni.com/content/docs/DOC-12324
http://sine.ni.com/cs/app/doc/p/id/cs-13888
I think that especially the first document could help you a bit further.
Another thing you could try is contacting the author of the case study to request if he can send you his code.
Kind Regards,
Thierry C - Applications Engineering Specialist Northern European Region - National Instruments
CLA, CTA
If someone helped you, let them know. Mark as solved and/or give a kudo. Smiley Wink
Message 2 of 2 (173 Views)
Reply
