11-24-2015 06:41 PM
For this program, I need to generate a sine wave if some variable was true onto the analog output. This is what this part of the program looks like http://i.imgur.com/JrZFOZY.png
Sine Wave: http://i.imgur.com/dfYtoL6.png
DAQ: http://i.imgur.com/66YLwbH.png
It'll work for a bit but then I get this error: http://i.imgur.com/uL1Fm5M.png
Anyone have a suggestion as to what the issue might be? Specifically this is triggering whenever TRUE is passed in a second time - it'll work fine for the first TRUE input but then when we get TRUE being input again it doesn't work.
Solved! Go to Solution.
11-24-2015 07:33 PM
In the DAQ, try changing the Generation Mode to Finite Samples.
11-24-2015 08:29 PM
That worked perfectly. Thank you so much!
