07-13-2012 07:13 AM - edited 07-13-2012 07:15 AM
When I Generate report using Word Report Generation VIs ,the error is generated.
This is my Vi
can somebody tell the error reason?
The attaché is Vi (one is 2011,other is 8.6)
07-13-2012 07:52 AM
probe 6 is error
07-13-2012 08:28 AM
07-13-2012 08:50 AM
I have using this
So the path to my template is relative path, and the template extension .doc is correct.
Can you run my Vi
Thank you!
07-13-2012 10:31 AM
07-14-2012 02:37 AM - edited 07-14-2012 02:38 AM
I had modifyied the relative path to this:
But the error is apperaed:
probe 14 15 16 is error
07-14-2012 02:43 AM
Are you the Vi is coreect when you modified the path ?
Can you pass me your run VI?
07-14-2012 05:48 AM
I can't run your code without error since my MS Word doesn't recognize chinese characters. What you are seeing is an error that was hidden by the first one (the file not found error). The error you are showing is after the Word Update Graph vi. To use this vi you first need to have a graph in your template, which is not the case, that's why you get an MS Word error message. You can use the Word Easy Graph vi instead.
Ben64
07-14-2012 07:56 AM - edited 07-14-2012 08:03 AM
Hi Ben64
Thank you! The problem is solved.
BUT when I use the Word Easy Graph vi ,the result is
I want the Graph (curve),like as:
How Can I do get the picture.
I have other problem. I want to get default name for the new word file.
liang
07-14-2012 08:52 AM
